I’ve used klipper for a while now. I have a single setup for triggering the M112 (emergency stop) command (using my Voron Tap as a trigger) and it works great to avoid smashing the nozzle.
I have had this setup for a while and it works great but with a new print, I’m running into a problem where my printer will run for several hours and then throw a M112 command (emergency stop). I wanted to verify that it was coming from the Voron Tap trigger, so I did this:
[gcode_button kill_switch]
pin: ^!sb2209:PB6
press_gcode: KILL_ME_NOW
[gcode_macro KILL_ME_NOW]
M117 SB TAP Kill Switch Activated!
M118 SB TAP Kill Switch Activated!
M112
Then to verify that I could see those messages, I manually triggered the emergency stop by lifting the Tap. In the console and on the LED screen I see the message, BUT IT DIDN’T WRITE IT TO THE klippy.log FILE!? I can see that the M112 was issued but there is no mention in klippy.log of the “SB TAP Kill Switch Activated!” message.
How is someone supposed to debug this system without being able to get a debug statement to show up in the klippy.log file record??
Try adding a RESPOND statement like:
RESPOND TYPE=error MSG="M112 Error Thrown"
before the M112 gcode instruction.
This should give you a console message as well as writing to klippy.log.
thanks for the suggestion. I just tried it and no dice…
I changed the macro to this:
RESPOND TYPE=error MSG="SB TAP Kill Switch Activated!"
M112
and my log file looks like this after triggering it:
Stats 2512288.0: gcodein=0 mcu: mcu_awake=0.004 mcu_task_avg=0.000005 mcu_task_stddev=0.000002 bytes_write=3937 b>
Stats 2512289.1: gcodein=0 mcu: mcu_awake=0.004 mcu_task_avg=0.000005 mcu_task_stddev=0.000002 bytes_write=3943 b>
Stats 2512290.1: gcodein=0 mcu: mcu_awake=0.004 mcu_task_avg=0.000005 mcu_task_stddev=0.000002 bytes_write=3949 b>
Stats 2512291.1: gcodein=0 mcu: mcu_awake=0.004 mcu_task_avg=0.000005 mcu_task_stddev=0.000002 bytes_write=3955 b>
Stats 2512292.1: gcodein=0 mcu: mcu_awake=0.004 mcu_task_avg=0.000005 mcu_task_stddev=0.000002 bytes_write=3961 b>
Stats 2512293.1: gcodein=0 mcu: mcu_awake=0.004 mcu_task_avg=0.000005 mcu_task_stddev=0.000002 bytes_write=3967 b>
Stats 2512294.1: gcodein=0 mcu: mcu_awake=0.004 mcu_task_avg=0.000005 mcu_task_stddev=0.000002 bytes_write=3973 b>
Stats 2512295.1: gcodein=0 mcu: mcu_awake=0.004 mcu_task_avg=0.000005 mcu_task_stddev=0.000002 bytes_write=3979 b>
Stats 2512296.1: gcodein=0 mcu: mcu_awake=0.004 mcu_task_avg=0.000005 mcu_task_stddev=0.000002 bytes_write=3985 b>
Transition to shutdown state: Shutdown due to M112 command
Dumping gcode input 0 blocks
Dumping 20 requests for client 3911352656
Received 2512255.824696: b'{"id": 4034800240, "method": "objects/query", "params": {"objects": {"heaters": null}}}'
Received 2512255.824825: b'{"id": 4065687248, "method": "gcode/script", "params": {"script": "_SET_TIMELAPSE_SETUP >
Received 2512255.824825: b'{"id": 4034799696, "method": "gcode/script", "params": {"script": "HYPERLAPSE ACTION=STO>
Received 2512256.055717: b'{"id": 4065990480, "method": "objects/subscribe", "params": {"objects": {"webhooks": nul>
Received 2512256.306401: b'{"id": 4047218032, "method": "objects/subscribe", "params": {"objects": {"webhooks": nul>
Received 2512256.671915: b'{"id": 4047453648, "method": "info", "params": {}}'
I saw that RESPOND command and tried it out manually but I couldn’t get it to write the klippy.log file.
Sorry - I thought that would update the klippy.log.
Hopefully somebody else can point you in the right direction.
Thank you @Sineos, this was just what the doctor ordered!
