My Biqu B1 (SKR 1.4) is on its way to Klipper. On the SKR 1.4 I have attached a MKS PWC module, which can detach the whole printer from AC. The Raspi is powered from the PSU of the Biqu B1.
In Marlin I configured a delay of 3 minutes to turn off the MKS PWC. In this time, the Raspi can make a clean shutdown.
Is it possible to do this with Klipper without rewiring the MKS PWC to the Raspi?
Shutdown command to the raspberry - #4 by Fuksas showed me how to do a system shutdown from a menu entry. I think you could probably build on that to invoke system shutdown and add a timer to toggle a pin on the SKR to turn off the PWC (if that’s how it works). Basically:
system shutdown
UPDATE_DELAYED_GCODE ID=turn_off_pwc DURATION=180
With a [delayed_gcode turn_off_pwc] that sets the pin? Just spitballing…
