MKS Robin E3 + MKS PWC
Hi there! Anyone running successfully MKS PWC with Klipper? Especially with Ender 3 furnished with MKS Robin E3?
Essentially what the MKS PWC does is automatically shutting down the printer after the print is finished. It works as expected with Marlin, but when I try it Klipper the printer just shuts down after a second or two after being switched on.
The PWC is connected to the board via 2 sets of cables. The PWC’s PW_DET connects to Robin E3’s MT_DET (PB10) (also used for filament runout sensor) and the PWC’s PW_OFF connects to Robin E3’s PA14
The piece of code in Marlin to allow all that is:
Enable #define PSU_CONTROL
Set #define PSU_ACTIVE_STATE HIGH
and the pins are configured as:
#if ENABLED(PSU_CONTROL)
  #ifndef PS_ON_PIN
    #define PS_ON_PIN         PA14    //PW_OFF, you can change it to other pin
  #endif
  #ifndef KILL_PIN
    #define KILL_PIN          PB10    //PW_DET, you can change it to other pin
  #endif
  #define KILL_PIN_STATE      true     //true : HIGH level trigger
#endif
And the MKS PWC:
[https://www.aliexpress.com/item/32853300039.html](https://www.aliexpress.com/item/32853300039.html)
Anyone can suggest how to translate that into Klipper?
I have been searching for the answer to this question also. This is the problem with Klipper. Not many are willing to help or know how to help.
There is a solution to disable the printer, you need to rebuild the printer firmware for the clipper
see here: Klipper config for MKS PWC V3.0? · Issue #18 · makerbase-mks/Klipper-for-MKS-Boards · GitHub
Hello @halfback2012 !
Thank you for your input.
You noticed that your have been quite late to this discussion?
grafik
A lot of things changed since then.
