Hi there.
I installed Klipper on my Ender 3 which is upgraded with MKS Robin E3 and Triangle labs 3D touch. It works however, I have two main issues:
#1. My display is stuck with a “boot” message on it. I suspect I’m missing at all the “display” config in the config file and I have no idea how to configure it. - ie. pin numbers etc.
#2. The bltouch only probes one point in the middle of the bed, and I believe I’d set it to test 9 points.
Here’s my config:
# This file contains common pin mappings for MKS Robin E3 boards. To
# use this config, the firmware should be compiled for the STM32F103.
# When running "make menuconfig", enable "extra low-level
# configuration setup", select the 20KiB bootloader, and serial (on
# USART1 PA10/PA9) communication.
# Note that the "make flash" command does not work with MKS Robin
# boards. After running "make", run the following command:
# ./scripts/update_mks_robin.py out/klipper.bin out/Robin_e3.bin
# Copy the file out/Robin_e3.bin to an SD card and then restart the
# printer with that SD card.
# MKS Robin E3 has onboard TMC2209. This config can also be used for
# MKS Robin E3D if equipped with TMC2209 stepper drivers.
[stepper_x]
step_pin: PC0
dir_pin: PB2
enable_pin: !PC13
rotation_distance: 40
endstop_pin: ^PA12
position_endstop: 0
position_max: 235
homing_speed: 50
[stepper_y]
step_pin: PC2
dir_pin: PB9
enable_pin: !PB12
endstop_pin: ^PA11
position_endstop: 0
position_max: 235
homing_speed: 50
step_pin: PC14 #PC14 if using board v1.1
dir_pin: !PC15 #PC15 if using board v1.1
enable_pin: !PB8
rotation_distance: 8
# endstop_pin: ^PC6
position_min: -2 # The Z carriage may need to travel below the Z=0
# homing point if the bed has a significant tilt.
# position_endstop: 0
position_max: 250
step_pin: PB4
dir_pin: PB3
enable_pin: !PB5
rotation_distance: 33.683
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PC9
sensor_pin: PA0
control: pid
pid_Kp: 26.196
pid_Ki: 1.468
pid_Kd: 116.901
min_temp: 0
max_temp: 250
[tmc2209 stepper_x]
uart_pin: PC7
run_current: 0.800
hold_current: 0.500
stealthchop_threshold: 999999
[tmc2209 stepper_y]
uart_pin: PD2
run_current: 0.800
hold_current: 0.500
[tmc2209 stepper_z]
uart_pin: PC12
run_current: 0.650
hold_current: 0.450
[tmc2209 extruder]
uart_pin: PC11
run_current: 0.800
hold_current: 0.500
[fan]
pin: PA8
[heater_bed]
heater_pin:PC8
sensor_pin: PA1
control: pid
pid_kp = 65.278
pid_ki = 1.630
pid_kd = 653.598
min_temp: 0
max_temp: 130
[bltouch]
sensor_pin: ^PC6
control_pin: PA3
pin_move_time: 0.500
pin_up_reports_not_triggered: True
pin_up_touch_mode_reports_triggered: False
x_offset: -44
y_offset: -12
#z_offset: 0.7
speed: 2
# The safe_z_home section modifies the default G28 behavior
[safe_z_home]
home_xy_position: 117,117
speed: 50
z_hop: 15
z_hop_speed: 5
[force_move]
enable_force_move: True
[bed_mesh]
speed: 100
horizontal_move_z: 10
mesh_min: 54,22
mesh_max: 230,215
probe_count: 3,3
restart_method: command
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 3000
max_z_velocity: 5
max_z_accel: 100
#[display]
#Taken from teh Ender 3 config file
#lcd_type: st7920
#cs_pin: PA3
#sclk_pin: PA1
#sid_pin: PC1
#encoder_pins: ^PD2, ^PD3
#click_pin: ^!PC0
# EXP1 / EXP2 (display) pins
[board_pins]
aliases:
# EXP1 header
EXP1_1=PC3, EXP1_3=PA4, EXP1_5=PA6, EXP1_7=PC4, EXP1_9=<GND>,
EXP1_2=PC1, EXP1_4=PA5, EXP1_6=PA7, EXP1_8=PC5, EXP1_10=<5V>,
# EXP2 header
EXP2_1=PB14, EXP2_3=PB11, EXP2_5=PB0, EXP2_7=PC10, EXP2_9=<GND>,
EXP2_2=PB13, EXP2_4=PA15, EXP2_6=PB15, EXP2_8=<RST>, EXP2_10=<NC>
# See the sample-lcd.cfg file for definitions of common LCD displays.
#*# [bltouch]
#*# z_offset = 0.750
Any ideas, guys?
