Error loading kinematics 'cartesian'
Hello I’am trying to run klipper on ‘my Ender-3’ with ‘mks robin e3d’ for the first time.
I can’t find which part is wrong
please let me know if you know where the problem is
Thanks in advance!!
error message
Once the underlying issue is corrected, use the "RESTART"
Printer is halted
===== Config file =====
[printer]
kinematics = cartesian
max_velocity = 300
max_accel = 2000
max_z_velocity = 5
max_z_accel = 100
[tmc2209 stepper_x]
uart_pin = PC7
run_current = 0.800
hold_current = 0.500
[stepper_x]
step_pin = PC0
dir_pin = PB2
enable_pin = !PC13
microsteps = 16
rotation_distance = 40
endstop_pin = ^PA12
position_endstop = 0
position_max = 165
homing_speed = 50
[tmc2209 stepper_y]
uart_pin = PD2
run_current = 0.800
[stepper_y]
step_pin = PC2
dir_pin = PB9
enable_pin = !PB12
microsteps = 16
endstop_pin = ^PA11
position_max = 165
homing_speed = 50
[tmc2209 stepper_z]
uart_pin = PC12
run_current = 0.650
hold_current = 0.450
step_pin = PC14
dir_pin = !PC15
enable_pin = !PB8
microsteps = 16
rotation_distance = 8
position_max = 200
[tmc2209 extruder]
uart_pin = PC11
run_current = 0.800
step_pin = PB4
dir_pin = PB3
enable_pin = !PB5
microsteps = 16
rotation_distance = 33.500
nozzle_diameter = 0.400
filament_diameter = 1.750
heater_pin = PC9
sensor_pin = PA0
control = pid
pid_kp = 21.527
pid_ki = 1.063
pid_kd = 108.982
min_temp = 0
max_temp = 250
[heater_bed]
heater_pin = PC8
sensor_pin = PA1
control = pid
pid_kp = 54.027
pid_ki = 0.770
pid_kd = 948.182
min_temp = 0
max_temp = 130
[fan]
pin = PA8
[bltouch]
sensor_pin = ^PC6
control_pin = PA3
x_offset = -60
y_offset = -13
z_offset = 2.95
samples = 2
[board_pins]
aliases =
  CR_EXP3_10=<5V>, CR_EXP3_8=PA4, CR_EXP3_6=PA6, CR_EXP3_4=<RST>, CR_EXP3_2=PC3,
  CR_EXP3_9=<GND>, CR_EXP3_7=PA5, CR_EXP3_5=PB0, CR_EXP3_3=PB11,  CR_EXP3_1=PC1
[display]
lcd_type = st7920
sid_pin = PA4
cs_pin = PA5
sclk_pin = PA6
encoder_pins = ^PB0, ^PB11
click_pin = ^!PC3
[virtual_sdcard]
path = ~/sdcard
serial = /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
  File "/home/pi/klipper/klippy/toolhead.py", line 256, in __init__
    self.kin = mod.load_kinematics(self, config)
  File "/home/pi/klipper/klippy/kinematics/cartesian.py", line 142, in load_kinematics
    return CartKinematics(toolhead, config)
  File "/home/pi/klipper/klippy/kinematics/cartesian.py", line 16, in __init__
    for n in 'xyz']
  File "/home/pi/klipper/klippy/stepper.py", line 386, in LookupMultiRail
    rail = PrinterRail(config)
  File "/home/pi/klipper/klippy/stepper.py", line 268, in __init__
    self.add_extra_stepper(config)
  File "/home/pi/klipper/klippy/stepper.py", line 347, in add_extra_stepper
    pin_params = ppins.parse_pin(endstop_pin, True, True)
  File "/home/pi/klipper/klippy/pins.py", line 210, in parse_pin
    desc = pin_desc.strip()
AttributeError: 'NoneType' object has no attribute 'strip'
Config error
  File "/home/pi/klipper/klippy/klippy.py", line 157, in _connect
    self._read_config()
  File "/home/pi/klipper/klippy/klippy.py", line 143, in _read_config
    m.add_printer_objects(config)
  File "/home/pi/klipper/klippy/toolhead.py", line 600, in add_printer_objects
    config.get_printer().add_object('toolhead', ToolHead(config))
  File "/home/pi/klipper/klippy/toolhead.py", line 264, in __init__
    raise config.error(msg)
Error: Error loading kinematics 'cartesian'
webhooks client 3041261888: New connection
webhooks client 3041261888: Client info {'program': 'Moonraker', 'version': 'v0.7.1-42-g81176a6'}
Does your printer.cg really contain all these blank lines? Make sure that the cfg
  • does not contain surplus blanks etc
  • does not contain surplus blank lines
  • is unix end-of-line format (do not edit with windows notepad or similar)
Also your config is missing endstop_pin: probe:z_virtual_endstop in [stepper_z] section
