Printer Model: Anycube Kossel Liner Plus
MCU / Printerboard: SKR 1.4 Turbo
I am getting the following error on my delta printer, using Cura and Mainsail on Rassberry P4.
Not sure what is the issue as I am new to klipper.
I am able to Calebrate and Mes Level. But when I try and print I get this error Move out of range: 9.300 1.410 0.300 [-6.500].
klippy-2.log (297.8 KB)
tetra
November 28, 2024, 4:16am
2
line 10: Unable to open config file /home/alexp1tx/printer_data/config/printer.cfg
@tetra
That appears only at the beginning of the log.
Important is the end of the log.
(Else there would not be the OOR error)
Make sure your calibration radius is the same or smaller than your print radius.
Are you able to home the effector? Move effector up/down or left/right?
system
Closed
February 6, 2025, 11:30pm
5
