Hi everyone. I have problem with my ender 3 v2 with dimensional accuracy.
When I print an object X axis always smaller than Y axis in dimension.
For example when try printing 30mm square with fillets at corners X axis around 29.75,Y axis around 29.95.
I have no problem with my Y axis only in x axis. I checked printers frame all looks good and square, I could not find any skew.
My belts are tightened at 9.5N with 76hz in X axis, 91hz in Y axis.
Also when I check movement without printing X axis seems to move accurately. Would you help me please. I am searching this problem about a couple of days but could not find any solution. I did not print skew compansation print yet, I prefer fixing it mechanicaly first if I can. I tried higher microstep, lower microstep, interpolation on/off, belts loose or tight, different motor with different pulley, lower or higher current, fans on/ off and tried different slicer.
I can compansate it when if I change rotation distance but Probably deviation will be much higher in big prints. I just want to measure equal both x and y axis dont expecting to be perfectly 30mm because of shrinkage
Flow is calibrated also I am uploading my config file and a couple of photos of my printer.
Update: Tried new belt on x axis but results are same.
printer.cfg (12.9 KB)
