Doubts about temperatures and slicers
Printer Model: Vcore 31
MCU / Printerboard: Octopus Max
Host / SBC Rpi4
klippy.log (10).txt (51.8 KB)
In my workflow, when I turn on the printer, I have it preheat via the web interface to temperatures close to the printing temperature.
Each print job is configured to a different temperature for the first layer and the rest of the print using the slicer; in my case, I usually use ORCA.
Well, the temperature remains at the one I’ve set to preheat the printer. It doesn’t change even if a different temperature is selected in the slicer, at least not when I use Klipper.
I suppose this is a problem with the slicer itself, rather than Klipper.
Is there any way to force this to happen? When I start printing, I want the printer to reach the temperature specified in the slicer, instead of using the one I’ve preselected.
Another issue, which I suspect is related, is that I used to use Cura, and the startup routine was different. The printer was preheated, and I gave it the command to print a gcode, which had different temperatures than the preheating temperature I had indicated, because the printing did NOT start until the temperature was the one I had configured in CURA.
Please post the start gcode that is in your slicer.
Have you coped the start code from CURA to OrcaSlicer 1:1?
Keep in mind, that these slicers have different tokens for the gcode start setup.
I use macros, so the startup G-code is the same regardless of the slicer I use…
My macro that runs the slicer is:
“EMPEZAR_IMPRESION”
and it contains this:
 [gcode_macro EMPEZAR_IMPRESION]
    G90 ;Coordenadas absolutas
    G1 Z20.0 F6000 ;Move the platform down 15mm    ; Prime the extruder
    G92 E0
    BED_MESH_CLEAR
    BED_MESH_CALIBRATE ADAPTIVE=1
    BED_MESH_PROFILE SAVE=<MallaAnterior>
    M220 S20
    G28 Z
In that macro, no temperature values are passed over.
You can do the temperature settings in OrcaSlicer.
With my settings the start gcode in OrcaSlicer is this:
M82
M355 S1                                     ; OP
M106 P0 S0
M106 P1 S0
M140 S[bed_temperature]
M109 S([first_layer_temperature_0] * 0.75) T0
M190 S[bed_temperature]
M109 S[first_layer_temperature_0] T0
G90
BED_MESH_CLEAR
G28
I’ve modified the macro to start printing; I’ve included those two lines… I’ll check it on the next print job…
    G92 E0
    BED_MESH_CLEAR
    M220 S20
    G28 Z
What I find strange is the difference in temperature management between ORCA and CURA (and I think Prusa Slic3r, I’m not sure). The other slicers seem to be doing things more reasonably…
No, these belong to the OrcaSlicer start gcode.
