Printer Model: Custom
MCU / Printerboard: Duet 3 Mini 5+ and Duet 1LC Toolboard
Host / SBC: RPi 4 8GB
klippy.log: Not Applicable
Hello! I’m in the process of converting a custom Duet-based build from RRF to Klipper, and am having some difficulties understanding how to implement the toolboards. (There are currently two 1LC boards, with plans to add more.)
While these toolboards are mentioned in the documentation, I have yet to find anything resembling a guide, reference example, or even pin mappings.
My understanding is that I will need to purchase a USB to CAN adapter, and connect it directly to the Pi. I’ve been looking at the CANable v2.0 Pro. The tool distribution board is currently wired into the Mini 5+ itself, and I was hoping I would be able to use the existing hardware, but I’m starting to get the sense that that would be monumentally more difficult.
But again, I can’t find any concrete examples of people actually getting these boards working with Klipper, despite plenty of posts that indicate it’s possible. (Like this one or this one.)
Normally, I’d just go for it and only come here if I run into problems, but because I would need to purchase new hardware and flash the boards with no clear way of going back, I want to make sure that it’s possible first, especially since there is NO publicly available documentation that I have been able to find regarding what to do after getting the board flashed and connected. Downtime is at a premium, unfortunately.
To add further confusion, the CAN bus documentation claims that only the stm32, SAME5x series, and rp2040 chips are compatible, making no mention of the SAMDC21.
If this is a lost cause, and I need to replace these toolboards with compatible alternatives, I would love it if anyone has any suggestions.
Thank you for any help that you can provide in this matter.
