button
October 29, 2023, 4:07pm
1
Printer Model: Voron v0.1
MCU / Printerboard: OrangePi Zero2W / Duet3 Mini 5+
[klippy.log|attachment](upload://alfIbnNfmMLzJXSPDaLpyFL0JtS.log) (117.8 KB)
Hi
I know is my 3rd topic in a week, but first all the time I’m looking online for solution and when cant find answer opening new topic.
I had working configuration of Duet3 mini with RRF and Fysetc 12864 mini lcd. I swaped fw to klipper, and this is the last thing need to be done.
When I enable display i have an error:
Invalid SERCOM configuration
when i add:
spi_bus = sercom1
Invalid combination of TX pin and CLK pin
sercom0, sercom2, sercom3, sercom7 causing error:
What can i do?
ReXT3D
October 29, 2023, 4:17pm
2
You may need to potentially dig into RRF header files for the Mini to get your answer. FWIW, I am using my Mini with the SPI based RTD daughter card which is configured on sercom7 as follows (only pertinent excerpt shown):
[samd_sercom sercom7]
## define PT100 daughter card sercom
sercom: sercom7
tx_pin: PC12
rx_pin: PC15
clk_pin: PC13
spi_bus: sercom7 # must be defined earlier
This may help you define sercom1
properly…
Sineos
October 29, 2023, 5:04pm
3
button
October 29, 2023, 6:02pm
4
Yes, I do.
But didnt notice order and need to use sercom (in example there is spi_bus: spi
and this was unclear for me).
Now my config looks:
sercom: sercom7
tx_pin: PC12
rx_pin: PC15
clk_pin: PC13
[display]
lcd_type: uc1701
cs_pin: PC6
a0_pin: PA2
spi_bus: sercom7
contrast: 63
encoder_pins: ^PC11, ^PD1
click_pin: ^!PB9
And screen works briliant. THX
system
Closed
December 28, 2023, 6:02pm
5
