Hi all, I have a Sovol SV-01 with a Creality 2.2.1 Silent Board (see attached pic of the board). I used the E1 connector to control the 2nd Z motor; worked great under Marlin v2. Now trying to switch to Klipper. Not sure what values to put in the printer.cfg file…
[stepper_z1]
step_pin: # Z(0) is PL3
dir_pin: # Z(0) is !PL1
enable_pin: # Z(0) is !PK0
rotation_distance: 8
# endstop_pin: ^PD3 # using a BLTouch...
# position_endstop: 0 # using a BLTouch...
position_max: 300
Thank you for your help!
