Printer Model: Voron 2.4
MCU / Printerboard: Octopus V1.1 with EBB SB2240 Canbus card on Stealthburner
I have the latest version of klipper/moonraker/fluid running on my voron 2.4 and the ebb sb2240 hooked up and running. The issue is that in the extruder section, when I add in the following section
[tmc2240 extruder]
cs_pin: EBBCan: PA15
spi_software_sclk_pin: EBBCan: PB10
spi_software_mosi_pin: EBBCan: PB11
spi_software_miso_pin: EBBCan: PB2
driver_TPFD: 0
run_current: 0.650
stealthchop_threshold: 0
the Fluiddpi UI is showing two extruders as shown in the following picture.
If I remove the tmc2240 extruder section and add in the tmc2209 extruder section, I am not seeing two different extruder temperatures. Obviously I can’t run using the tmc2209 driver as I have the 2240 driver, but it appears that there is something going on with the tmc2240 extruder section of the code.
I haven’t tried running mainsail, only fluid.
