Elegoo Neptune 4 Pro Internal error during connect; CommandWrapper instance has no attribute get_command_tag
Printer Model: Elegoo Neptune 4 Pro
MCU / Printerboard:MKSPI
klippy log.zip (2.1 MB)
once the underlying issue is corrected, use the RESTART. command to reload the config and restart the host software printer is halted
I updated Klipper and Moonraker while connected to fluidd now my printer has stopped working.
I am new to 3d printing and was trying to install a webcam for while prints are going in the room next door so i didn’t have to be up and down all the time, i noticed in the Klipper interface there were some files that could be updated, being fresh to this i thought what harm can it do to update the files … so i did and then received the error mentioned above. when i seen it stopped working i then put the firmware that came with the printer on usb stick and tried to see if that helped but it is still stuck with the same error… any help would be greatly appreciated … if there is help could you explain in most easiest way ELI5
i can hardwire into printer to get onto fluidd interface but i really don’t know what to do.
i hope i have explained what is wrong properly … i have attached a klippy log if that helps … thank you.
Please see CommandWrapper instance has no attribute 'get_command_tag' and MKSPI Elegoo Neptune 4 PRO ERROR:commandwrapper instance has no attribute 'get_command_tag'
