Printer Model: CR-10S
MCU / Printerboard: BTT SKR E3 Mini V3.0
moonraker.log
moonraker.log (196.0 KB)
I’ve been experiencing random lost connections for a month or so. Mid print, the SBC stops and errors out "Lost MCU connection ‘mcu’ ". What I’ve done to diagnose it:
Changed the SBC to a different one, (Odroid XU4 → OrangePi 3LTS)
Changed Linux distro (Debian Bullseye, Dietpi 8.2.x)
Changed USB cable/taped the 5V pin
Reinstalled/reflashed everything
Lowered Baud to 115200
Tested the connection via the Command Dispatch Benchmark
Changed SBC and cable routes, trying to lower possible interferences
The klippy.log is quite unhelpful. It shows a Got EOF when reading from device (line 11954.0) after a small spike in bytes_retransmit (from 9 to 44). While this does usually indicate a poor USB cable, I don’t think it’s the true cause here. I’ve changed a couple, with no observable differences.
Moonraker and dmesg show nothing of relevant (other than the usual USB reconnect line). Interestingly, after an error-induced shutdown, Moonraker has trouble reconnecting to Klipper and hangs on the connecting screen until you reboot the SBC. I’m running two instances, but I couldn’t assess whether the second printer (undergoing “maintenance”) is affected too. I’m starting to run out of options here.
[Update]
After it occurred again, I tried to reconnect immediately, which resulted in Klipper hanging indefinitely in the “Startup” phase. No amount of firmware restart solved it, only rebooting the SBC. It’s also interesting how Mainsail showed the MCU with its load during startup, meaning Klipper was able to get an initial connection. So it’s a MCU firmware issue?
