End stops triggered when they are not
Printer Model: Ender 3 Pro
MCU / Printerboard: BTT SKR E3 V2
Hello again!
klippy (5).log (1.4 MB)
So this keep is happening. I’ve swapped out the end stops with others i had and still the same, I’ve check the cables are plugged into the correct ports in the board and i can not figure out why this is happening.
It does not change either if i manually press them and then send m119 command to check.
Help would be greatly apprenticed.
Thanks
Have you tried inverting the input pin signal?
