Ender 3 Motherboard 4.2.2 Chip gd32f303
Printer Model: Ender 3
MCU / Printerboard: 4.2.2
Good afternoon! How are you? I recently bought a BTT Pi v1.2. The installation went smoothly, and everything is fine in MainSail as well. However, when I tried to install the Klipper firmware on my Ender 3, I couldn’t find support for the GD32F303 processor and couldn’t install it. I tried, but the screen just stays blue, and MainSail says the connection port can’t be found. I’ve tried several commands, but I keep getting an “access denied” error. Do you have a solution?
You have a dificult task ahead. See:
If you search the entire Klipper Discourse you’ll find 8 threads on your exact issue.
I had a V4.2.2 board years ago. The SD firmware update process (even with Marlin firmware) was a total coin flip. The board doesn’t change the filename so you never know if it actually flashed. If it won’t connect you don’t know if it is bad firmware or a bad flash.
Review the instructions at Creality for updating firmware. The process is exactly the same no matter what .bin file you are trying to flash.
Read the threads for tips and tricks.
