Ender 3 pro 4.2.2 with sonic pad
Printer Model: ender 3 pro
MCU / Printerboard:4.2.2
klippy.log (70.4 KB)
So I recently got an ender 3 pro 4.2.2 from a friend and upgraded to a sprite dual extruder with a cr touch I’m currently trying to hook up the sonic pad I’ve also acquired I’m having issues with the setup of the auto leveling of the bed the sprite extruder crashes into the front left of the bed and the cr touch hangs off the front in the initial setup auto bed leveling I know the x and y need to be changed so the cr touch stay on the bed but I’m not sure the input on those numbers or how to put them into the sonic pad thanks in advance
Please read this:
So with the new update it should have the correct x & y input for the sprite extruder
Latest was released Jan 13, 2024
Edit: The Klipper source files in “Creality_Sonic_Pad_V1.0.6.54.20” have a date from Dec 14, 2023
So I have downloaded the new firmware and I’m still having the same issues with the head crashing into bed on auto level
Why don’t you reveal your klippy.log? This is requested when starting a new topic.
Maybe your problem isn’t relate to the Creality Sonic Pad firmware?
Nobody here can help you with your Creality Sonic Pad. Their firmware isn’t open source, so?
Good luck. hcet14
my bad it took me a few to figure this out im new here my apologies
The SonicPad klippy.log is still the Cre@lity klippy.crap.
There is nothing useful in it. Not even the printer config.
