Ender 3 S1 Plus - Verify Heater error for extruder
Printer Model: Ender 3 S1 Plus
MCU / Printerboard: STM32F401XC
Host / SBC: (aarch64, 64bit)
Hi, quite new to to te klipper setup. Just installed it a couple days ago using KIAUH and got it setup with mainsail, moonraker and klipper ofcourse. I’ve got a raspberry pi 4 connected using usb-c to my ender 3 s1 plus via the front IO.
Also setup the printer.cfg file. If needed I can attatch it later to this topic. All warnings are gone, I go through the Ellis tuning guide and everything works fine. Just about to start my first print and I get this error/warning which blocks me from printing.
I’ve looked through these forms and see that it mainly reduces down to a couple of issues. But what I can see from the tests i perform this just happens when heating the print-head. Which earlier when tuning worked just fine when heating up…
If i run the PID_CALIBRATE HEATER=extruder TARGET=200 command I get this error. running the same command for the heater_bed works fine.
Hopefully someone here could help me out so I could get my first print with this firmware going. :').
Much thanks in advance!
klippy (6).log (3.8 MB)
The reason for the error message is this:
caused by
and
  • The heater cartridge gets no power due to a broken/detached cable
  • The extruder thermistor is detached from the hotend
  • The driver MOSFET on the board is broken.
Thanks for your quick response. Lucky it was an easy solution, I think the cable loosened when changing out to a new filament…
Closing the issue :slight_smile:
