Hi all i getting this error
MCU ‘mcu’ shutdown: Rescheduled timer in the past
This generally occurs when the micro-controller has been
requested to step at a rate higher than it is capable of
obtaining.
Printer is shutdown
I tried to slower myprint but some times its ok some time it shown this error on the same gcode. I use direct extruder dual z and skr mini v3 board. Pressure advance is calibrated. There is my log
klippy.log (2.5 MB)
