Ender 3 v2 Heater extruder not heating at expected rate
Printer Model: Moded ender 3 v2 Old Creality Spider Hotend.
MCU / Printerboard: creality
Host / SBC Mainsail
Hi Guys,
i have just started getting this issue and klipper randomly shuts down. it started when i had some filament which stuck itself to a reel and wouldn’t unwind. I am printing with PETG
Hot end is the older creality spider with longer nozzles
See the ‘verify_heater’ section in docs/Config_Reference.md
Printer is shutdown
thanks
All
logs-20240701-112449.zip (1.6 MB)
See Heater <name> not heating at expected rate
Checked cables, thermistors seems to track correctly. Issue happens randomly during the print cycle. The graph looks good, what I have noticed is the the State % increases to maintain the same temp. Would this be the heater dying?
No idea, but you can 99.9% sure that the reason is among those listed in the linked article. Some issues only will appear when hot or when moving etc.
Have you checked when cold?
During print:
Some connectors and/or bad crimps can change connectivity when getting warm.
Also, have the power leads to the EBB board sufficient diameter for the power?
Stays the heater mosfet on the board cool?
