Heater extruder not heating at expected rate SKR MINI E3 V3
Printer Model: Ender 3 v2 Sprite Pro Extruder
MCU / Printerboard: SKR Mini E3 V3
Host / SBC Raspberry Pi 5 4GB
Hi everyone,
I’m running Klipper on my Ender 3 V2 and recently swapped in an SKR Mini E3 V3. When I try to heat up the hotend or heaterbed, I get the following error:
“Heater extruder not heating at expected rate
See the ‘verify_heater’ section in docs/Config_Reference.md for the parameters that control this check.”
I’ve double-checked my configuration files, but I’m not sure what exactly is causing this issue. Has anyone encountered a similar problem? Any advice or other troubleshooting steps would be greatly appreciated.
Thanks in advance for your help!
Klippy Log from 192.168.68.80 (1).log (101.9 KB)
printer.cfg (5.7 KB)
Klipper is correctly:
  • Setting the target temperature
  • Setting the output to 100% (PWM = 1)
However, the actual temperature is not changing at all. This issue is likely due to:
  • A defective heating cartridge
  • Problems with the wiring, such as broken wires or a defective connector.
