Endoscope messing with my printer?
Printer Model: CR10 Smart Pro
MCU / Printerboard: stock CR10 smart pro
Host / SBC Raspberry pi 3
klippy.zip (3.8 MB)
Prints randomly stop and I get Klipper had to shutdown error.
I’m using the official raspberry pi 3 power supply, I have 2 webcams hooked to it.
Can somebody check my log? Is it because of my second nozzle cam (endoscope from aliexpress) ?
Hello @caste1200 !
When you have the feeling, the USB cams could be the issue, have you already tried without them?
I’m trying now. But I thought the Log would give a better idea and faster, not wasting another 8h print haha
If the webcam was the issue, how can solve it and use both webcams? Plug it somewhere else? What exactly makes it incompatible?
It is known that some USB cameras have a negative impact on the USB bus. Exactly why, e.g. too high data rate, too much power, bad camera firmware implementation etc., is not known.
Often these SBCs have only one USB controller, so it is not possible to separate devices to different buses (not sure how RPI handles it).
Sometimes a hub can help.
It’s an HD camera and on moonracker camera setting was set to 1080, maybe lowering the resolution down to its native HD res should help? Or it wouldn’t change anything?
