Printer Model: tripodmaker
MCU / Printerboard:
klippy.log (8.4 KB)
Is there a way to “guide” the enhanced delta calibration to get better dimensional accuracy on a delta printer? Or is there an alternative calibration method, I don’t have good results with the default method.
In between run 1 and run 2 was a “DELTA_ANALYZE CALIBRATE=extended”, it only seems to improve the spoke length but not much else. There is a large amount of variation (skewed pillars, not ok outer distances, …) which doesn’t really change before and after.
