Printer Model: Flsun QQSP
MCU / Printerboard: “hispeed” (robin nano)
I am in the process of calibrating my delta printer.
I have been using the guide for the “Enhanced Delta Calibration”
My process is as follows:
1 - Heat bed and nozzle to working temps
2 - Wait ~ five minutes
3 - DELTA_CALIBRATE
4 - SAVE_CONFIG
5 - Print “calibrate_size” model with recommended slicer settings
6 - Measure and enter all measurements
7 - Enter SCALE
8 - Then ANALYZE
9 - SAVE_CONFIG
After these steps ^^ I move to verify proper calibration:
10 - Heat machine again
11 - BED_MESH_CALIBRATE
12 - SAVE-CONFIG
13 - Print “calibrate_size” model with recommended slicer settings
14 - Measure model and find model not quite perfect. I would like to calibrate again…
At this point, do I simply start at STEP 1 in order to perform a second Enhanced Calibration to achieve even more accurate results?
Thanks
