Cant delta calibrate/probe calibrate
Printer Model: Flsun SW
MCU / Printerboard: SKR 1.4
Host / SBC RPI 3b
klippy.log (2.0 MB)
Hello. So I moved my printer on the table and like every delta, It needed recalibrate after this. But I cant get past any calibration. I can do probe_calibrate, it will end succesfully, but on the beginning I receive error as on the image. If I do delta_calibrate command, it will probe only diameter around 4cm from my 20cm bed, then ends with endless loop of working on calibration in the console, need to hard shut down the printer. I checked my config files, macros etc, deleted variables for probe and bed calibration, but it is still the same. Any advice? Running on latest klipper on both MCU and RPi. Manual delta calibration is the same, it moves only on 4cm diameter from the middle of the bed. My bed and delta radius is same as before in config, but it seems to me, that delta_calibrate command is ignoring my bed radius somehow.
Is your nuzzle lose some how?
I used to get that cause the hotend holder melt a little bit, cause nuzzle not in place a little.
Double check the hardware if u try a lot on software.
So it was some weid SW problem. Had to delete all the content on the bottom of printer.cfg, uncomment default delta arms length, radius, probe offset etc. Then re-run callibration and it started working. Strange.
