Fill out above information andin all cases attach yourklippy.logfile (use zip to compress it, if too big). Pasting yourprinter.cfgis not needed Be sure to check our “Knowledge Base” Category first. Most relevant items, e.g. error messages, are covered there
…Hello , Issues with delta_caliberate on klipper version : 13 , as nozzle keeps going down without stopping to calliberate various points, probe caliberate, G28 homing, query probe everything works well , i have tried to change endstop positions to different numbers but still nozzle doesnt stop, please help. nozzle crashing into bed.
Changing monitoring state from “Offline” to “Opening serial connection”Connecting to port /tmp/printer, baudrate 230400Changing monitoring state from “Opening serial connection” to “Connecting”Connected to: Serial<id=0xa78448b0, open=True>(port=‘/tmp/printer’, baudrate=230400, bytesize=8, parity=‘N’, stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitorSend: N0 M110 N0125Recv: okSend: N0 M110 N0125Changing monitoring state from “Connecting” to “Operational”Recv: okSend: N0 M110 N0125Recv: okSend: N1 M11539Recv: ok FIRMWARE_NAME:Klipper FIRMWARE_VERSION:v0.13.0-303-gac6f059cbSend: M21Recv: okSend: M105Recv: ok T:0Send: STEPPER_BUZZ STEPPER=stepper_aRecv: okSend: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: QUERY_ENDSTOPSRecv: stepper_a:open stepper_b:open stepper_c:openRecv: okSend: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: G91Recv: okSend: G28 Z0Recv: okSend: G90Recv: okSend: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: GET_POSITIONRecv: // mcu: stepper_a:926 stepper_b:1207 stepper_c:1231Recv: // stepper: stepper_a:1355.777745 stepper_b:1355.777745 stepper_c:1355.777745Recv: // kinematic: X:-0.000000 Y:0.000000 Z:600.000000Recv: // toolhead: X:-0.000000 Y:0.000000 Z:600.000000 E:0.000000Recv: // gcode: X:-0.000000 Y:0.000000 Z:600.000000 E:0.000000Recv: // gcode base: X:0.000000 Y:0.000000 Z:0.000000 E:0.000000Recv: // gcode homing: X:0.000000 Y:0.000000 Z:0.000000Recv: okSend: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: QUERY_PROBERecv: // probe: openRecv: okSend: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: PROBE_CALIBRATERecv: // probe at -0.000,0.000 is z=572.625000Recv: // Starting manual Z probe. Use TESTZ to adjust position.Recv: // Finish with ACCEPT or ABORT command.Recv: // Z position: ??? → 577.625 ← ???Recv: okSend: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: TESTZ Z=-1Recv: // Z position: ??? → 576.625 ← 577.625Recv: okSend: TESTZ Z=-1Recv: // Z position: ??? → 575.625 ← 576.625Recv: okSend: M105Recv: ok T:0Send: TESTZ Z=-1Recv: // Z position: ??? → 574.625 ← 575.625Recv: okSend: M105Recv: ok T:0Send: TESTZ Z=-1Recv: // Z position: ??? → 573.625 ← 574.625Recv: okSend: M105Recv: ok T:0Send: TESTZ Z=-1Recv: // Z position: ??? → 572.625 ← 573.625Recv: okSend: M105Recv: ok T:0Send: ACCEPTRecv: // probe: z_offset: 0.000Recv: // The SAVE_CONFIG command will update the printer config fileRecv: // with the above and restart the printer.Recv: okSend: M105Recv: ok T:0Send: SAVE_CONFIGRecv: okRecv: // Klipper state: DisconnectSend: M105Recv: ok T:0Recv: // Klipper state: ReadySend: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: M105Recv: ok T:0Send: G28Recv: okSend: M105Recv: ok T:0Send: M105Recv: ok T:0Send: DELTA_CALIBRATESend: M112Send: N2 M11235Send: N3 M104 T0 S034Recv: // Klipper state: ShutdownClosing serial port due to emergency stop M112.Changing monitoring state from “Operational” to “Offline after error”Connection closed, closing down monitor
