FLSUN Q5 + Artillery Ruby 1.2: DELTA_CALIBRATE crashes into bed
Printer Model: FLSunQ5
MCU / Printerboard: Artillery Ruby 1.2
Host / SBC: Raspberry Pi zero 2W
Hi everyone, I’m looking for some help with a Klipper setup on my FLSUN Q5, which I’m running with an Artillery Ruby 1.2 MCU. I swapped in this board after accidentally damaging the original one, and it was the only spare I had available.
The initial configuration went pretty smoothly:
• I generated the printer.cfg correctly.
• Endstops are working and detected properly.
• The probe works too — if I run the PROBE command, it triggers and stops as expected when it touches the bed.
The issue starts when I try to run DELTA_CALIBRATE: As soon as I start it, the printhead crashes straight into the bed. It seems like the probe isn’t triggering at all during the calibration. The same thing happens if I try DELTA_CALIBRATE METHOD=manual. I noticed that the Z movement is 4x greater than expected — for example, if I send G1 Z25, the head moves 100 mm instead.
Thinking it might be a rotation_distance issue, I tried reducing the value to 1/4, but then the motors just whine and don’t move at all.
My questions:
  1. ⁠⁠Could Klipper be interpreting the steps/mm incorrectly due to the Artillery Ruby 1.2 board?
  2. ⁠⁠Is there something wrong in my driver setup or rotation_distance values? 3. Why does the PROBE command work, but DELTA_CALIBRATE seems to ignore it completely?
Any suggestions or insight would be greatly appreciated. Thanks in advance!
Hi @link96 ,
Dividing your rotation distance by four will multiply the motor’s motion by four times.
Does multiplying the rotation distance by four work instead?
It seems strange. The configuration appears to closely follow the defaults for this printer. Did you modify anything?
You’re right — I miscalculated my rotation_distance. After fixing that, DELTA_CALIBRATE seems to work fine without any other changes.
I honestly didn’t expect the probe trigger to stop working during calibration just because of incorrect movement scaling. Definitely learned something here — thanks for pointing me in the right direction!
The issue is resolved now. Thanks again!
