klippy.log (101.2 KB)
Hello,
I have completed the delta calibrate, bed_mesh_calibrate, and probe_calibrate. Unfortunately when I try to print a model, the nozzle always digs into the build plate. I have tried adjusting the z_offset manually which according to the probe_calibrate is 16.525 and reducing the number (by 10 mm as a sanity check) so it would not move the print head so far down but no matter what it continues to engrave the print skirt into my plate. No idea what I am doing wrong. I have attached the klippy.log file. Please help.
Thanks in advance.
