Error Klipper version is: v...-dirty
Printer Model: Voron 2.4
MCU / Printerboard: BTT Octopus pro with SB2209 and cartographer
Host / SBC : BTT Pi v1.2
klippy.log (86.3 KB)
octopus.cfg (19.1 KB)
I am getting this error:
Your Klipper version is: v0.12.0-404-g80d185c94-dirty
MCU(s) which should be updated:
mcu: Current version v0.12.0-404-g80d185c94
EBBCan: Current version v0.12.0-404-g80d185c94
scanner: Current version Cartographer 4.0.0
Up-to-date MCU(s):
I got that after flashing updated FW on the mainboard and the SB2209 so I tought I did a mistake somewhere. I have reinstalled klipper from scratch (with KIAUH) to try to fix this and everything was going well until I rebooted. After the reboot the same error showed up again.
This is my first printer with klipper and I am totally lost right now. I also know that my cartographer is outdated, it all began because I was trying to update the FW but klipper could not see it on can0 after the last update.
git describe do not show the “dirty” tag but still I tryed “git reset --hard 80d185c94” without success.
The printer was working perfectly before the update.
Any help would be greatly appreciated.
Thanks
I could only post 2 links since I’m a new user. Here is the printer.cfg file and the moonraker log
printer.cfg (1.8 KB)
moonraker.log (84.2 KB)
After fighting with it most of the day I reinstalled Armbian + Klipper for a 3rd time and for some reasons it is now working.
One thing I noticed was that it seemed to be the cartographer install script that was screwing up Klipper. On my second reinstall everything was working untill I run the script. On the third time I updated the cartographer FW before installing the script and now Kliper isn’t seen as dirty. Is it the true cause, I have no idea but it’s working now so I’m happy.
