Hallo,
I am just another 3D Printer who wants to use Klipper, but has very little clues about all the coding stuff. So when just following the Instructions keeps producing this error I can’t help myself.
I do have an Ender 3 V2 with the 4.2.2. Board. This is from my log
Last MCU build version: v0.9.1-502-g338bc82d
Last MCU build tools: gcc: (15:7-2018-q2-6) 7.3.1 20180622 (release) [ARM/embedded-7-branch revision 261907] binutils: (2.31.1-11+rpi1+11) 2.31.1
Last MCU build config: BUS_PINS_i2c1=PB6,PB7 BUS_PINS_i2c2=PB10,PB11 RESERVE_PINS_USB=PA11,PA12 BUS_PINS_i2c1a=PB8,PB9 STEP_DELAY=2 ADC_MAX=4095 BUS_PINS_spi3=PB4,PB5,PB3 BUS_PINS_spi2=PB14,PB15,PB13 BUS_PINS_spi1=PA6,PA7,PA5 PWM_MAX=255 MCU=stm32f103xe STATS_SUMSQ_BASE=256 CLOCK_FREQ=72000000
Build file /home/pi/klipper/klippy/…/out/klipper.elf(100908): Mon May 24 10:17:47 2021
Wait for identify_response
File “/home/pi/klipper/klippy/serialhdl.py”, line 65, in _get_identify_data
params = self.send_with_response(msg, ‘identify_response’)
File “/home/pi/klipper/klippy/serialhdl.py”, line 249, in send_with_response
File “/home/pi/klipper/klippy/serialhdl.py”, line 306, in get_response
cmd_queue)
File “/home/pi/klipper/klippy/serialhdl.py”, line 241, in raw_send_wait_ack
raise error(“Serial connection closed”)
error: Serial connection closed
Unable to connect
Do you see a mistake I made, or can you give me a solution to this problem?
