I’m new in klipper and trying to bring it up on my stm32f4-attached-to-duex5-3D-printer. I don’t have any endstops, and klipper refuses to work w/o endstop pins specified, so i tried to use my TMC2660’s stallguard instead as specified in the configuration documentation and examples. Now klipper complains about the chip missing, even though it’s all defined in the config. What am i doing wrong? Here’s the log:
Starting Klippy...
Args: ['/home/cnc/klipper/klippy/klippy.py', '/home/cnc/printer.cfg', '-l', '/tmp/klippy.log']
Git version: 'v0.9.1-518-gd6197964-dirty'
CPU: 1 core ARMv6-compatible processor rev 7 (v6l)
Python: '2.7.16 (default, Oct 10 2019, 22:02:15) \n[GCC 8.3.0]'
Start printer at Sat Jun 5 22:51:29 2021 (1622929889.3 88803.6)
===== Config file =====
[stepper_x]
step_pin = PB8
dir_pin = PC14
endstop_pin = tmc2660_stepper_x:virtual_endstop
microsteps = 16
rotation_distance = 40
[tmc2660 stepper_x]
cs_pin = PB9
spi_bus = spi2
run_current = 1.0
sense_resistor = 0.051
[stepper_y]
step_pin = PA0
dir_pin = PB7
endstop_pin = tmc2660_stepper_y:virtual_endstop
microsteps = 16
[tmc2660 stepper_y]
cs_pin = PA1
spi_bus = spi2
run_current = 1
step_pin = PB5
dir_pin = PA3
endstop_pin = tmc2660_stepper_z:virtual_endstop
microsteps = 16
[tmc2660 stepper_z]
cs_pin = PB4
spi_bus = spi2
run_current = 1
step_pin = PB2
dir_pin = PC14
endstop_pin = tmc2660_extruder:virtual_endstop
microsteps = 16
nozzle_diameter = 0.4
filament_diameter = 1.75
min_temp = 0
max_temp = 280
[tmc2660 extruder]
cs_pin = PA6
spi_bus = spi2
run_current = 1
serial = /dev/ttyACM0
[printer]
kinematics = cartesian
max_velocity = 500
max_accel = 3000
max_z_velocity = 25
max_z_accel = 30
[virtual_sdcard]
path = ~/
Config error
File "/home/cnc/klipper/klippy/klippy.py", line 157, in _connect
self._read_config()
File "/home/cnc/klipper/klippy/klippy.py", line 143, in _read_config
m.add_printer_objects(config)
File "/home/cnc/klipper/klippy/toolhead.py", line 589, in add_printer_objects
config.get_printer().add_object('toolhead', ToolHead(config))
File "/home/cnc/klipper/klippy/toolhead.py", line 256, in __init__
self.kin = mod.load_kinematics(self, config)
File "/home/cnc/klipper/klippy/kinematics/cartesian.py", line 142, in load_kinematics
return CartKinematics(toolhead, config)
File "/home/cnc/klipper/klippy/kinematics/cartesian.py", line 16, in __init__
for n in 'xyz']
File "/home/cnc/klipper/klippy/stepper.py", line 357, in LookupMultiRail
rail = PrinterRail(config)
File "/home/cnc/klipper/klippy/stepper.py", line 257, in __init__
self.add_extra_stepper(config)
File "/home/cnc/klipper/klippy/stepper.py", line 336, in add_extra_stepper
mcu_endstop = ppins.setup_pin('endstop', config.get('endstop_pin'))
File "/home/cnc/klipper/klippy/pins.py", line 256, in setup_pin
pin_params = self.lookup_pin(pin_desc, can_invert, can_pullup)
File "/home/cnc/klipper/klippy/pins.py", line 239, in lookup_pin
pin_params = self.parse_pin(pin_desc, can_invert, can_pullup)
File "/home/cnc/klipper/klippy/pins.py", line 224, in parse_pin
raise error("Unknown pin chip name '%s'" % (chip_name,))
error: Unknown pin chip name 'tmc2660_stepper_x'
