Existing command 'TESTZ' not found in gcode_macro rename
I’m not able to create a gcode_macro for the TESTZ command. I would like to change the functionality so it auto reports the printer.configfile.save_config_pending_items.stepper_z.position_endstop variable.
The macro is as follows:
[gcode_macro TESTZ]
rename_existing: BASE_TESTZ
  BASE_TESTZ {rawparams}
  RESPOND TYPE=command MSG="printer.configfile.save_config_pending_items.stepper_z.position_endstop: {printer.configfile.save_config_pending_items.stepper_z.position_endstop}"
I get the error:
I believe this might be a bug as the TESTZ is not actually available until Z_ENDSTOP_CALIBRATE is run.
klippy.log (21.3 KB)
TESTZ is a command that is used during probe calibration and is only usable there. It is no regular gcode command.
Why do you want to change it?
https://www.klipper3d.org/Bed_Level.html#the-paper-test
I want to change it for development purposes. I would like it to automatically report the new resultant stepper_z.position_endstop.
