Extrude only move too long
i have switched to fluidd yesterday ,. moreover i had changed my ender3v2 to printed direct extruder
so when i start printing and after aprox 4% of the print …with no reason the extruder leave the bed to the back right … and extrude some filament >> then back to top left corner of the bed and … send " Extrude only move too long"
i can resume the print again but it keeps doing the same again and again so i cancel the print
i used these in start gcode
G92 E0
G28
BED_MESH_CALIBRATE
again without start g code
19:12:50
!! Extrude only move too long (-600.000mm vs 100.000mm)
See the ‘verify_heater’ section in docs/Config_Reference.md
Printer is shutdown
with another print …
Need a log to offer help, but my guess is you have a mistake in one of your macros.
i remembered that i have replaced original plastic Ender 3 extruder with clone metal one
ill attach all logs plus printer cfg
printer (2).cfg (8.1 KB)
moonraker-obico-7125.log (179.9 KB)
moonraker (6).log (28.3 KB)
klippy (6).log (29.8 KB)
Post a sliced gcode file that shows the error and also a klippy.log that shows the error
Hello Sineos
I believe that i have made something in the Cura settings … but i don’t know what i tired different 2 sliced gcode so attached below … i hope u help me as u usually do
thnx bro
klippy (7).log (2.0 MB)
trial5_AlchemyCubeTake2.txt (6.9 MB)
here is the sliced gcode file but i had to change it to txt file so i can i attached it here
There are multiple issues:
Filament Sensor Filament_runout_sensor: runout event detected, Time 3099.05
Exiting SD card print (position 201168)
Stats 3099.3: gcodein=0 mcu: mcu_awake=0.006 mcu_task_avg=0.000028 mcu_task_stddev=0.000025 bytes_write=627381 bytes_read=153941 bytes_retransmit=9 bytes_invalid=0 send_seq=11631 receive_seq=11631 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=72000315  heater_bed: target=65 temp=65.0 pwm=0.266 raspberry_pi: temp=68.7 mcu_temp: temp=46.0 sysload=0.11 cputime=126.800 memavail=3610604 print_time=569.483 buffer_time=1.981 print_stall=0 extruder: target=220 temp=219.9 pwm=0.824
Stats 3100.3: gcodein=0 mcu: mcu_awake=0.006 mcu_task_avg=0.000028 mcu_task_stddev=0.000025 bytes_write=628575 bytes_read=154189 bytes_retransmit=9 bytes_invalid=0 send_seq=11652 receive_seq=11652 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=72000316  heater_bed: target=65 temp=64.9 pwm=0.325 raspberry_pi: temp=68.7 mcu_temp: temp=46.0 sysload=0.11 cputime=126.852 memavail=3610604 print_time=570.737 buffer_time=2.232 print_stall=0 extruder: target=220 temp=220.0 pwm=0.824
Stats 3101.3: gcodein=0 mcu: mcu_awake=0.006 mcu_task_avg=0.000028 mcu_task_stddev=0.000025 bytes_write=628728 bytes_read=154357 bytes_retransmit=9 bytes_invalid=0 send_seq=11657 receive_seq=11657 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=38 stalled_bytes=0 freq=72000317  heater_bed: target=65 temp=65.0 pwm=0.280 raspberry_pi: temp=69.1 mcu_temp: temp=46.0 sysload=0.11 cputime=126.897 memavail=3610424 print_time=571.817 buffer_time=2.309 print_stall=0 extruder: target=220 temp=220.0 pwm=0.824
Stats 3102.3: gcodein=0 mcu: mcu_awake=0.006 mcu_task_avg=0.000028 mcu_task_stddev=0.000025 bytes_write=629077 bytes_read=154584 bytes_retransmit=9 bytes_invalid=0 send_seq=11665 receive_seq=11665 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=11 stalled_bytes=0 freq=72000317  heater_bed: target=65 temp=64.8 pwm=0.822 raspberry_pi: temp=68.7 mcu_temp: temp=46.0 sysload=0.10 cputime=126.943 memavail=3610336 print_time=575.861 buffer_time=5.351 print_stall=0 extruder: target=220 temp=219.9 pwm=0.874
Stats 3103.3: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000029 mcu_task_stddev=0.000026 bytes_write=629161 bytes_read=154772 bytes_retransmit=9 bytes_invalid=0 send_seq=11671 receive_seq=11671 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=72000316  heater_bed: target=65 temp=65.0 pwm=0.173 raspberry_pi: temp=68.7 mcu_temp: temp=46.0 sysload=0.10 cputime=126.984 memavail=3610336 print_time=575.861 buffer_time=4.348 print_stall=0 extruder: target=220 temp=220.1 pwm=0.776
Stats 3104.3: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000029 mcu_task_stddev=0.000026 bytes_write=629211 bytes_read=154950 bytes_retransmit=9 bytes_invalid=0 send_seq=11675 receive_seq=11675 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=10 stalled_bytes=0 freq=72000317  heater_bed: target=65 temp=65.0 pwm=0.198 raspberry_pi: temp=67.7 mcu_temp: temp=46.0 sysload=0.10 cputime=127.024 memavail=3610248 print_time=575.861 buffer_time=3.343 print_stall=0 extruder: target=220 temp=220.1 pwm=0.776
Stats 3105.3: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000029 mcu_task_stddev=0.000026 bytes_write=629248 bytes_read=155137 bytes_retransmit=9 bytes_invalid=0 send_seq=11678 receive_seq=11678 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=72000317  heater_bed: target=65 temp=65.0 pwm=0.259 raspberry_pi: temp=69.1 mcu_temp: temp=45.9 sysload=0.10 cputime=127.063 memavail=3610256 print_time=575.861 buffer_time=2.341 print_stall=0 extruder: target=220 temp=220.1 pwm=0.776
Stats 3106.3: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000029 mcu_task_stddev=0.000026 bytes_write=629632 bytes_read=155325 bytes_retransmit=9 bytes_invalid=0 send_seq=11687 receive_seq=11687 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=72000320  heater_bed: target=65 temp=65.0 pwm=0.121 raspberry_pi: temp=68.2 mcu_temp: temp=45.9 sysload=0.10 cputime=127.110 memavail=3610132 print_time=579.669 buffer_time=5.145 print_stall=0 extruder: target=220 temp=220.2 pwm=0.725
Stats 3107.3: gcodein=0 mcu: mcu_awake=0.007 mcu_task_avg=0.000029 mcu_task_stddev=0.000026 bytes_write=629679 bytes_read=155498 bytes_retransmit=9 bytes_invalid=0 send_seq=11690 receive_seq=11690 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=11 stalled_bytes=0 freq=72000320  heater_bed: target=65 temp=65.0 pwm=0.291 raspberry_pi: temp=69.1 mcu_temp: temp=45.9 sysload=0.09 cputime=127.151 memavail=3610132 print_time=579.669 buffer_time=4.142 print_stall=0 extruder: target=220 temp=220.1 pwm=0.829
Stats 3108.3: gcodein=0 mcu: mcu_awake=0.003 mcu_task_avg=0.000020 mcu_task_stddev=0.000014 bytes_write=629732 bytes_read=155704 bytes_retransmit=9 bytes_invalid=0 send_seq=11694 receive_seq=11694 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=72000319  heater_bed: target=65 temp=65.0 pwm=0.362 raspberry_pi: temp=68.2 mcu_temp: temp=46.0 sysload=0.09 cputime=127.191 memavail=3610132 print_time=579.669 buffer_time=3.139 print_stall=0 extruder: target=220 temp=220.1 pwm=0.829
Stats 3109.3: gcodein=0 mcu: mcu_awake=0.003 mcu_task_avg=0.000020 mcu_task_stddev=0.000014 bytes_write=629784 bytes_read=155867 bytes_retransmit=9 bytes_invalid=0 send_seq=11698 receive_seq=11698 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=72000317  heater_bed: target=65 temp=65.0 pwm=0.117 raspberry_pi: temp=68.7 mcu_temp: temp=46.0 sysload=0.09 cputime=127.232 memavail=3610284 print_time=579.669 buffer_time=2.135 print_stall=0 extruder: target=220 temp=220.1 pwm=0.829
Stats 3110.3: gcodein=0 mcu: mcu_awake=0.003 mcu_task_avg=0.000020 mcu_task_stddev=0.000014 bytes_write=629993 bytes_read=156070 bytes_retransmit=9 bytes_invalid=0 send_seq=11704 receive_seq=11704 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=10 stalled_bytes=0 freq=72000316  heater_bed: target=65 temp=65.0 pwm=0.136 raspberry_pi: temp=69.1 mcu_temp: temp=46.0 sysload=0.09 cputime=127.276 memavail=3610188 print_time=581.675 buffer_time=3.137 print_stall=0 extruder: target=220 temp=220.1 pwm=0.829
Stats 3111.3: gcodein=0 mcu: mcu_awake=0.003 mcu_task_avg=0.000020 mcu_task_stddev=0.000014 bytes_write=630077 bytes_read=156257 bytes_retransmit=9 bytes_invalid=0 send_seq=11710 receive_seq=11710 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=72000314  heater_bed: target=65 temp=65.0 pwm=0.050 raspberry_pi: temp=69.1 mcu_temp: temp=45.9 sysload=0.09 cputime=127.319 memavail=3610400 print_time=581.675 buffer_time=2.135 print_stall=0 extruder: target=220 temp=220.1 pwm=0.790
Extrude only move too long (-600.000mm vs 99.800mm)
See the 'max_extrude_only_distance' config option for details
Your filament sensor is misbehaving and suddenly throws a runout. This triggers your runout gcode which tries to extrude an insane amount of filament:
G1 E10 F300
G1 E20 F150
In total the runout gcode makes no sense at all. This more looks like a purge event for changing filament color.
START G-CODE:
START_PRINT T_BED=70 T_EXTRUDER=225
This is from your sliced file. Your start gcode is wrong. Basically you are trying to execute two macros here:
START with the parameter G-CODE:
START_PRINT with the parameters T_BED=70 T_EXTRUDER=225
Both macros do not exist
as usual … u gave the solution
thnx a lot … the run out sensor was the problem … and also im going to adjust my slicer setting too
one last thing
i want to prevent any thing from update .. it usually having connection problem after any update
so in moonraker.conf
[update_manager]
enable_auto_refresh: True
this enabled fluidd updates
[update_manager client fluidd]
type: web
repo: fluidd-core/fluidd
path: ~/fluidd
[include moonraker-obico-update.cfg]
how can i cancel the auto update .. will it harm any thing in the system
thnx in advance bro
