Extruder doesn't extrude
Hello everyone, when I print the extruder, after few layers, doesn’t extrude anymore.
Why?
This is the klipper log:
klippy.log (397.7 KB)
Have you checked the extruder mode?
Could it be that the printer is in absolute mode and the slicer is in relative mode?
Your log is showing Timer too close errors.
Where I can check they and, in case, change they?
In the slicer.
What slicer du you use?
There is a setting for the slicing and one in the slicer’s start code for the printer (M82/M83)
https://reprap.org/wiki/G-code#M82:_Set_extruder_to_absolute_mode
https://reprap.org/wiki/G-code#M83:_Set_extruder_to_relative_mode
I use Cura.
Which between M82 and M83 I have to use?
Depends on what you want to use.
Important is, that in the slicer and in the slicer’s start code is set the same
Ok, thank you
