OK, almost there!
Test cube printed, now under extrusion or flowrate issue (apparently!)…
I measured the filament out of the extruder to 120mm, extruded 100mm, and measurement after extrusion shows 96.45mm…I don’t really understand which parameters I have to alter in my printer.cfg…
Are you going with this guide?
Hiya!
Yep, this guide!
Checking my printer.cfg, I noticed the rotation_distance being set at 33.5 (as per the sample config file…
I just changed it to 8 (I have Z on leadscrews), test print in progress, looks 1 000 000 times better already!
