Hi everyone. Does anyone know what the pin should be for the probe? I can’t get it to work with anything I’ve tried.
Creality Silent Board 2.2.1
CR-10 S5
EZABL
Petsfang Blokhead
CR-10 S5
EZABL
Petsfang Blokhead
I’ve been trying to set it up using the ender 5 plus settings but with no luck so far.
step_pin: PL3
dir_pin: PL1
enable_pin: !PK0
rotation_distance: 4
position_max: 480
position_min: -15
homing_speed: 10.0
step_pin: PA4
dir_pin: PA6
enable_pin: !PA2
rotation_distance: 33.683
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PB4
sensor_pin: PK5
control: pid
pid_kp = 25.159
pid_ki = 1.421
pid_kd = 111.330
min_temp: 0
max_temp: 265
[safe_z_home]
home_xy_position: 225, 225
speed: 100
z_hop: 10
z_hop_speed: 5
[probe]
pin:^PD3
x_offset: -45
y_offset: -10
z_offset: 1.0
speed: 3
#[bltouch]
#sensor_pin: ^PD3
#control_pin: PB5
#x_offset: -45
#y_offset: 0
#z_offset: 0
#speed: 20
#pin_up_touch_mode_reports_triggered: False
[bed_mesh]
speed: 150
horizontal_move_z: 8
mesh_min: 30, 0
mesh_max: 315, 350
probe_count: 5, 5
[bed_screws]
screw1:30,40
screw1_name:1
screw2:325,40
screw2_name:2
screw3:325,295
screw3_name:3
screw4:30,295
screw4_name:4
Ok I’ve got it sorted out. Just had to figure out how to reverse triggered/open by adding a ! to the pin.
pin: !PD3
