Peurif
July 30, 2022, 3:58pm
1
until yesterday i was using a BlTouch, but i am giving a try to Inductive zprobe (Pinda style), these model PEPPERL AND FUCHS NBN2,5-8GM35-E1L.
But i dont know how configure it… someone can give info?
The last error i am receiving its: “Unknown pin conchip name ‘probe’”. Seems related, not sure, that in config i have
This works with BlTouch…but no with Pinda style zprobe
Where i can find info?
Thanks
Dear Peurif, you should not use probe:z_virtual_endstop as endstop, just use the pin where the peperl and fuchs is connected
Peurif
March 15, 2023, 4:32am
3
Thx… I haved solved…
Its working perfect for months
Sorry, can you elaborate?
Why not? Works like a charme!
Depending on the printer model he can perform Z_TILT with it and not only homing Z.
Suppose you have connected your sensor to a pin called PE1, as an example
Then, in the printer.cfg, inside [stepper_z], you should not write
The right line must look like this one
endstop_pin: PE1
Or may be you need to invert the behaviour of the sensor, in this case:
endstop_pin: !PE1
That’s all
Sineos
March 20, 2023, 6:24am
7
If you use the probe for homing as well (which typically is done), then the only correct notation is endstop_pin: probe:z_virtual_endstop
