Feature request: Automated gantry tilt adjustment like the bed tilt
Gantry skew issue - each side of gantry should be homed individually
I’m working on a large Cartesian format printer that has a relatively long gantry.
It is driven by two Y steppers (stepper_y & stepper_y1)
The problem is that the gantry has a skew issue and the skew value changes every new boot.
I want to configure the printer to automatically adjust the X-axis and the gantry(Y-axis) to be orthogonal.
The first idea is using two endstops to correct it like the bed tilting solution.
could you use two limit switches for the y and have each one be for each motor?
