Feature Request: Custom Gcode/Macro every n-th probe point on bed mesh
I’m using piezo sensors under the printbed like Bambulab does on X1 and P1. The sensor triggers when the printbed touches the nozzle. It works just fine for z homing, but on bed meshing the piezos need to be ‘refreshed’ from time to time. Bambulab does that by shaking the bed quickly up/down every 7th probe point.
Is there a way to implement a macro or gcode in bed mesh that will be executed every n-th probe point?
How it should work:
So, before the bed mesh the printer shakes the bed to reset the piezos and starts bed meshing with the first 7 probe points like normal. Before it probes the next 7 points an external macro/gcode is executed (for shaking the bed), then resumes with the next 7 probe points.
7 is just a random number here, user should be able to choose other numbers.
Thank you
