Filament Sensor
Printer Model: Wanhao Duplicator i3
MCU / Printerboard: Melzi (stock)
Host / SBC Raspi 4b
klippy.zip (1.7 MB)
New to klipper but I managed to figure it all out.
I am stumped as how to setup my run out sensor.
Machine is a basic Wanaho i3
I have the BTT SFS V1.0
It’s wired to GPIO 17 on the Raspi (plus 3.3 and gnd)
I just can’t figure out how to setup the sensor to work.
I tried all the suggested scripts but I just can’t seem to get it to acknowledge that the sensor is working.
I have it detecting when there is filament, but it doesn’t change state when there isn’t
Do I need to add anything to my START_PRINT macro in addition to the sensor code.
If you have a similar setup, I’d really appreciate hearing how I can get this working.
Thanks!
D
I don’t have any experience with the SFS 1.0 but I do with 2.0 and I found it to be something of a finnicky beast.
Question for you - is there an LED on the SFS 1.0 that gives you the operation status? On the 2.0, there’s a Red LED that lights when there is no filament in the sensor and a Blue LED that flashes when the filament is going through it.
Do you have anything like this so you can see the status of the SFS?
Regardless, I did a bit of checking and found this discussing that might be useful to you:
It sounds like you have to add a pull up to your Raspberry Pi IO pin (10k should be fine).
Thanks!
I have been banging my head against the wall, I am starting to think I have a defective unit.
Going to switch it for another and see what happens.
D
