Setup filament sensor with rpi and Mainsail
I’m trying to set-up a simple filament sensor that uses a micro switch (same switch as the ender3 z-axis) and connected to a raspberrypi. It’s wired as NC, with one wire going to gpio17 and the other going to ground.
The relevant parts of my printer.cfg…
[mcu host]
serial: /tmp/klipper_host_mcu
[filament_switch_sensor FilamentStatus]
pause_on_runout: True
switch_pin: host:gpio17
I’m fairly certain the MCU part is working correctly because I also have an ADXL345 wired to the rpi and it works.
So far in Mainsail I can see that the sensor is there but it always reads like I’m out of filament (whether the switch is closed or open).
Any thoughts?
EDIT: it’s actually wired NC, I updated it above.
Hi, I think you have to enable the gpis in the raspberry pi configuration. Run
sudo raspi-config then go into “Interface Options” and enable I2C and SPI in each submenu.
Hope this helps.
Thanks for the reply! Both are now enabled, but unfortunately it still does not work.
Here’s a little more detail…
When I enter gpioinfo it looks like gpio17 has been claimed by Klipper…
gpiochip0 - 54 lines:
        line   0:      unnamed       unused   input  active-high
        line   1:      unnamed       unused   input  active-high
        line   2:      unnamed       unused   input  active-high
        line   3:      unnamed       unused   input  active-high
        line   4:      unnamed       unused   input  active-high
        line   5:      unnamed       unused   input  active-high
        line   6:      unnamed       unused   input  active-high
        line   7:      unnamed   "spi0 CS1"  output   active-low [used]
        line   8:      unnamed   "spi0 CS0"  output   active-low [used]
        line   9:      unnamed       unused   input  active-high
        line  10:      unnamed       unused   input  active-high
        line  11:      unnamed       unused   input  active-high
        line  12:      unnamed       unused   input  active-high
        line  13:      unnamed       unused   input  active-high
        line  14:      unnamed       unused   input  active-high
        line  15:      unnamed       unused   input  active-high
        line  16:      unnamed       unused   input  active-high
        line  17:      unnamed    "klipper"   input  active-high [used]
        line  18:      unnamed       unused   input  active-high
Most likely you will need a pullup as well, like
grafik
Yes, this is the way! Thx @Sineos!
For reference, this is how it’s now wired…
I’m using a microswitch that already has this resistor…
…and I’ve wired Signal → gpio17, GND → ground, +VCC → 3.3V
I also updated my printer.cfg like this:
switch_pin: !host:gpio17
