I tried to use my raspberry pi model 3b+ as a secondary Mcu to control some cooling fan and lights beside the Arduino Mega 2560 which is the main control board for the printer axis movement related stuff.
Followed every instruction described in rpi as a secondary mcu at: //https://www.klipper3d.org/RPi_microcontroller.html//
changed the printer.cfg according to it as described by the reference document but keeps getting the error…
MCU 'rpi' shutdown: Unable to open out GPIO chip line
Printer is shutdown
This is my klippy.log:
klippy.log (1.2 MB)
My printer.cfg:
printer.cfg (9.1 KB)
when I am not including those fans and relays in my code everything is working fine that should verify that klipper is working fine and it’s installation is proper but defining the pins as:
pin: rpi:gpiochip0/gpio any pin number
is giving me that error.
I am defining my secondary mcu (Raspberry pi) as ‘rpi’.
I would also like to mention that I was using fluid with klipper before and at there everything was working as they should, then I tried to remote access my printer outside my home network and neither octopi or mainsail worked for me.
This is what my gpioinfo shows also I enabled SPI so that I could control the pins.
pi@mainsail:~ $ gpioinfo
gpiochip0 - 54 lines:
line 0: unnamed unused input active-high
line 1: unnamed unused input active-high
line 2: unnamed unused input active-high
line 3: unnamed unused input active-high
line 4: unnamed unused input active-high
line 5: unnamed unused input active-high
line 6: unnamed unused input active-high
line 7: unnamed “spi0 CS1” output active-low [used]
line 8: unnamed “spi0 CS0” output active-low [used]
line 9: unnamed unused input active-high
line 10: unnamed unused input active-high
line 11: unnamed unused input active-high
line 12: unnamed unused input active-high
line 13: unnamed unused input active-high
line 14: unnamed unused input active-high
line 15: unnamed unused input active-high
line 16: unnamed unused input active-high
line 17: unnamed unused input active-high
line 18: unnamed unused input active-high
line 19: unnamed unused input active-high
line 20: unnamed unused input active-high
line 21: unnamed unused input active-high
line 22: unnamed unused input active-high
line 23: unnamed unused input active-high
line 24: unnamed unused input active-high
line 25: unnamed unused input active-high
line 26: unnamed unused input active-high
line 27: unnamed unused input active-high
line 28: unnamed unused input active-high
line 29: unnamed unused input active-high
line 30: unnamed unused input active-high
line 31: unnamed unused input active-high
line 32: unnamed unused input active-high
line 33: unnamed unused input active-high
line 34: unnamed unused input active-high
line 35: unnamed unused input active-high
line 36: unnamed unused input active-high
line 37: unnamed unused input active-high
line 38: unnamed unused input active-high
line 39: unnamed unused input active-high
line 40: unnamed unused input active-high
line 41: unnamed unused input active-high
line 42: unnamed unused input active-high
line 43: unnamed unused input active-high
line 44: unnamed unused input active-high
line 45: unnamed unused input active-high
line 46: unnamed unused input active-high
line 47: unnamed unused output active-high
line 48: unnamed unused input active-high
line 49: unnamed unused input active-high
line 50: unnamed unused input active-high
line 51: unnamed unused input active-high
line 52: unnamed unused input active-high
line 53: unnamed unused input active-high
gpiochip1 - 2 lines:
line 0: unnamed “led0” output active-high [used]
gpiochip2 - 8 lines:
line 0: unnamed unused output active-high
line 1: unnamed unused output active-high
line 2: unnamed unused output active-high
line 3: unnamed unused output active-high
line 5: unnamed unused output active-high
line 6: unnamed unused output active-high
line 7: unnamed “led1” input active-high [used]
I need help…
Someone pls help me out its been 2 days, I can’t figure it on my own…|
