Problems setting up rpi mcu
Printer Model: Ender 3
MCU / Printerboard: SKR mini e3 V3
klippy.log klippy.zip (5.7 KB)
I have a fresh install of mainsail, I am trying to get input shaping running but keep getting the issue
mcu ‘mcu’: Unable to connect Once the underlying issue is corrected, use the “FIRMWARE_RESTART” command to reset the firmware, reload the config, and restart the host software. Error configuring printer
I have tried to run this setup Measuring Resonances - Klipper documentation on a raspberry pi but I have no idea what I have done wrong.
From line 811 in your klippy.log
serial = /dev/serial/by-id/usb-Klipper_stm32g0b1xx_4C000E001150415833323520-if00
	serial: /dev/ttyAMA0
	restart_method: command
Delete “serial: /dev/ttyAMA0” in your printer.cfg
Good luck, hcet14
I tried this now but unfortunately I’m still experiencing the same problem. I’ve also no completely reinstalled klipper but using the same config file I have the same issue which makes me wonder if my config has other issues?
Your section looks like:
restart_method: command: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-Klipper_stm32g0b1xx_4C000E001150415833323520-if00\nserial: /dev/ttyAMA0\nrestart_method: command'
Please change it to:
serial: /dev/serial/by-id/usb-Klipper_stm32g0b1xx_4C000E001150415833323520-if00
Important is to remove the indents at the beginning of the additional lines!
So I tried this but I still have the issue where uncomment
[mcu rpi]
serial: /tmp/klipper_host_mcu
results in klipper not being able to communicate with the printer anymore. Commenting this out allows the printer to work fine though.
I doubt that the printer will work fine without a communication with the RPi…
Can you please upload your latest printer.cfg?
In general, please always provide a corresponding klippy.log file.
