Printer is halted
I have only rudimental Linux knowledge and I just don´t where the problem might be.
I really hope that you can help me. The other knowledge base posts about the section header issues where not the same as mine, atleast I think so.
… klippy (2).log (7.3 KB)
Your printer.cfg is basically empty, doesn’t specify the path to the mainboard, and the \n usually points to corruption or wrong encoding, i.e. due to using an incompatible text editor, or copy/pasting from a document with the wrong encoding.
Sorry, I were only allowed to post 2 links max in my description. So this is the printer.cfg from the video above. Im not at home right now, so this one is without my own mcu, but at home I copied it at the right line.
It looks like the SAVE_CONFIG section is corrupted; it has config settings with no section header. It seems like this was probably a bed mesh that someone tried to remove but left some of the lines behind. You should probably just delete the entire section.
Thx, when I come home later I will try that out. Since I have no clue of coding and programming I was really adraid of deleting something since it clearly says to not removing anything beneath that line.
Thank you very much, will try that out. Yeah like I said, right now I´m not at home, this is the “blank” version from the video. At home I added my own mcu
But I would like to know, what does this part says and why do I have to delete it? Just curious.
This relates to a bed mesh. It makes no sense to have it in an example config anyway, as it is unique to each bed.
Furthermore, it is only a fragment / incomplete and that’s why your Klipper is not starting.
