Klipper config not reflecting properly
Printer Model: Ender 3 Pro
MCU / Printerboard: SKR E3 Mini V2.1
klippy.log (40.0 KB)
So as you can see from my log, Klipper is not connecting to the board because the MCU section is empty. However, I have since updated this entire file, and no matter how many times I reboot the new file IS NOT being reflected by Klipper which insists that it can’t find the board. The Klipper discord community and reddit are useless so far so this is a shot in the dark.
According to your log, there is nothing wrong. How do you determine that it is not working?
its a typo, it expects a colon not an = sign
see below for example
your printer.cfg:
serial = /dev/serial/by-id/usb-Klipper_stm32f103xe_38FFD8055057393512701343-if00
should be:
serial: /dev/serial/by-id/usb-Klipper_stm32f103xe_38FFD8055057393512701343-if00
edit: I updated to use your cfg as the example… :slight_smile:
