Hi there,
I’ve got a need to extrude filament with heater being OFF but whenever I try to do so I get the following:
“Max31865 Overvoltage or undervoltage fault
Printer is shutdown”
In order to extrude filament I use the following command:
G1 E100 F300
I set both min_temp: 10 and min_temp: 10 to minimum in the extruder config section
and max_extrude_only_distance is set to 500.0 so it should work but it won’t. The extruder starts moving filament but then the firmware crashes immediately.
My extruder config is show down below:
step_pin: PE2
dir_pin: PE3
enable_pin: !PD4
## Update value below when you perform extruder calibration
## If you ask for 100mm of filament, but in reality it is 98mm:
## rotation_distance = <previous_rotation_distance> * <actual_extrude_distance> / 100
## 22.6789511 is a good starting point
rotation_distance: 22.6789511 #Bondtech 5mm Drive Gears
## Update Gear Ratio depending on your Extruder Type
## Use 50:17 for Afterburner/Clockwork (BMG Gear Ratio)
## Use 80:20 for M4, M3.1
gear_ratio: 50:17 #BMG Gear Ratio
full_steps_per_rotation: 200 #200 for 1.8 degree, 400 for 0.9 degree
nozzle_diameter: 0.500
filament_diameter: 1.75
heater_pin: PA2
## Validate the following thermistor type to make sure it is correct
sensor_type: MAX31865 #ATC Semitec 104GT-2
sensor_pin: PA15 #PF4
# spi_bus: 3
spi_speed: 4000000
spi_software_sclk_pin: PB3
spi_software_mosi_pin: PB5
spi_software_miso_pin: PB4
rtd_nominal_r: 100
rtd_reference_r: 400
rtd_num_of_wires: 2
rtd_use_50Hz_filter: True
min_temp: 10
max_temp: 270
max_power: 1.0
min_extrude_temp: 10
control = pid
pid_kp = 16.716
pid_ki = 1.211
pid_kd = 57.671
#control = pid
#pid_kp = 26.213
#pid_ki = 1.304
#pid_kd = 131.721
## Try to keep pressure_advance below 1.0
pressure_advance: 0.05
## Default is 0.040, leave stock
pressure_advance_smooth_time: 0.040
max_extrude_only_distance: 500.0
Is this a bug?
Thanks.
Sineos: Edit formatting
