Flash Forge Creator Pro LCD Not working
Printer Model: Flash Forge Creator Pro all stock no modifications
MCU / Printerboard:Mightyboard REV_E (MightyBoard2560)
klippy.log (115.8 KB)
I have successflly flashed the bootloader using this method found here As I was trying to put Marlin on it but the parts fan never worked, so I decided to come to klipper. I have installed the firmware onto the board useing avrdude as per the printer.cfg file with the changed serial number, but the LCD doesnt work. And what I mean by that is there is no text on the 4 lines, I see on line 1 and 3 the blocks of pixels for characters (and no the constrast isnt turned up too much) any ideas The only thing I have changed in the menuconfig is the baud rate to 115200, but still upload at 57600
avrdude -c stk500v2 -p m2560 -P /dev/serial/by-id/usb-MakerBot_Industries_The_Replicator_85633323630351B050C0-if00 -b 57600 -D -U out/klipper.elf.hex
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: reading input file “out/klipper.elf.hex”
avrdude: input file out/klipper.elf.hex auto detected as Intel Hex
avrdude: writing flash (31100 bytes):
Writing | ################################################## | 100% 7.50s
avrdude: 31100 bytes of flash written
avrdude: verifying flash memory against out/klipper.elf.hex:
avrdude: load data flash data from input file out/klipper.elf.hex:
avrdude: input file out/klipper.elf.hex contains 31100 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 6.54s
avrdude: verifying …
avrdude: 31100 bytes of flash verified
avrdude: safemode: Fuses OK (E:FD, H:D8, L:FF)
avrdude done. Thank you.
The error messages in your log indicate that the board is not correctly flashed with Klipper.
If you have successfully flashed a bootloader then repeat the flashing process with:
  1. Verify that is indeed an atmega2560
  2. make distclean && make menuconfig → Select the atmega2560, leave the rest as default
  3. Flash with: make flash FLASH_DEVICE=/dev/serial/by-id/usb-MakerBot_Industries_The_Replicator_85633323630351B050C0-if00
Otherwise try
  3. Flash with: avrdude -c stk500v2 -p m2560 -P /dev/serial/by-id/usb-MakerBot_Industries_The_Replicator_85633323630351B050C0-if00 -b 57600 -D -U out/klipper.elf.hex
Thanks for that I must of needed a clean or something but the second option worked. I just needed to do a make in between step 2 and 3 now for a test print
:~/klipper $ make
Creating symbolic link out/board
Building out/autoconf.h
Compiling out/src/sched.o
Compiling out/src/command.o
Compiling out/src/basecmd.o
Compiling out/src/debugcmds.o
Compiling out/src/initial_pins.o
Compiling out/src/gpiocmds.o
Compiling out/src/stepper.o
Compiling out/src/endstop.o
Compiling out/src/trsync.o
Compiling out/src/adccmds.o
Compiling out/src/spicmds.o
Compiling out/src/i2ccmds.o
Compiling out/src/pwmcmds.o
Compiling out/src/buttons.o
Compiling out/src/tmcuart.o
Compiling out/src/neopixel.o
Compiling out/src/pulse_counter.o
Compiling out/src/lcd_st7920.o
Compiling out/src/lcd_hd44780.o
Compiling out/src/spi_software.o
Compiling out/src/i2c_software.o
Compiling out/src/thermocouple.o
Compiling out/src/sensor_adxl345.o
Compiling out/src/sensor_angle.o
Compiling out/src/sensor_mpu9250.o
Compiling out/src/sensor_lis2dw.o
Compiling out/src/sensor_bulk.o
Compiling out/src/avr/main.o
Compiling out/src/avr/timer.o
Compiling out/src/avr/gpio.o
Compiling out/src/avr/adc.o
Compiling out/src/avr/spi.o
Compiling out/src/avr/i2c.o
Compiling out/src/avr/hard_pwm.o
Compiling out/src/avr/watchdog.o
Compiling out/src/avr/serial.o
Compiling out/src/generic/serial_irq.o
Building out/compile_time_request.o
Version: v0.12.0-85-gd785b396
Linking out/klipper.elf
Creating hex file out/klipper.elf.hex
darksplat@RPI4FFCP:~/klipper $ avrdude -c stk500v2 -p m2560 -P /dev/serial/by-id/usb-MakerBot_Industries_The_Replicator_85633323630351B050C0-if00 -b 57600 -D -U out/klipper.elf.hex
avrdude: writing flash (31096 bytes):
avrdude: 31096 bytes of flash written
avrdude: input file out/klipper.elf.hex contains 31096 bytes
avrdude: 31096 bytes of flash verified
