Flash-sdcard.sh fails in recent releases
Printer Model: Custom
MCU / Printerboard: BTT SKR-PRO 1.2 (stm32f407xx)
Host / SBC: Raspberry Pi 4
klippy.log: not applicable
Cannot update via flash-sdcard.sh anymore since 2 days. Might be connected to software_spi: set rate limiting ticks from the host · Klipper3d/klipper@abc76ee · GitHub
Command “./flash-sdcard.sh /dev/ttyAMA0 btt-skr-pro-v1.2” now fails with:
Flashing /home/someone/klipper/out/klipper.bin to /dev/ttyAMA0
Checking FatFS CFFI Build…
Connecting to MCU…Connected
Checking Current MCU Configuration…Done
MCU needs restart: is_config=1, is_shutdown=0
Attempting MCU Reset…Done
Waiting for device to reconnect…Done
MCU configuration failed, attempting restart
SD Card Flash Error: Failed to configure MCU
File “/home/someone/klipper/scripts/spi_flash/spi_flash.py”, line 1659, in main
spiflash.run()
File “/home/someone/klipper/scripts/spi_flash/spi_flash.py”, line 1601, in run
self.run_reactor_task(self.run_verify)
File “/home/someone/klipper/scripts/spi_flash/spi_flash.py”, line 1582, in run_reactor_task
k_reactor.run()
File “/home/someone/klipper/klippy/reactor.py”, line 292, in run
g_next.switch()
File “/home/someone/klipper/klippy/reactor.py”, line 340, in _dispatch_loop
timeout = self._check_timers(eventtime, busy)
File “/home/someone/klipper/klippy/reactor.py”, line 158, in _check_timers
t.waketime = waketime = t.callback(eventtime)
File “/home/someone/klipper/klippy/reactor.py”, line 48, in invoke
res = self.callback(eventtime)
File “/home/someone/klipper/scripts/spi_flash/spi_flash.py”, line 1569, in run_verify
self.mcu_conn.configure_mcu()
File “/home/someone/klipper/scripts/spi_flash/spi_flash.py”, line 1371, in configure_mcu
self._configure_mcu_spibus(printfunc=printfunc)
File “/home/someone/klipper/scripts/spi_flash/spi_flash.py”, line 1321, in _configure_mcu_spibus
raise MCUConfigError(“Failed to configure MCU”)
MCUConfigError: Failed to configure MCU
I have the same issue and I can confirm, that reverting software_spi: set rate limiting ticks from the host · Klipper3d/klipper@abc76ee · GitHub fixes the issue.
This is probably a fix.
Hope that helps.
Indeed, that’s the fix. I experimented with those lines before too as is didn’t seem to make a lot of sense to add what’s been sent, but I didn’t remove that line. Silly me. Thank you!
