Heya, I just tryed flashing my MCU’s SD card with the script provided by klipper.
This is what I have done:
sudo service klipper stop
cd ~/klipper
git pull
make clean
make menuconfig
make
./scripts/flash-sdcard.sh /dev/ttyACM0 btt-skr-turbo-v1.4
it all ends with this:
Flashing /home/pi/klipper/out/klipper.bin to /dev/ttyACM0
Checking FatFS CFFI Build...
Connecting to MCU...Connected
Checking Current MCU Configuration...Done
MCU needs restart: is_config=1, is_shutdown=0
Attempting MCU Reset...Done
Waiting for device to reconnect....Done
Initializing SD Card and Mounting file system...
SD Card Flash Error: Failed to Initialize SD Card. Is it inserted?
File "/home/pi/klipper/scripts/spi_flash/spi_flash.py", line 1159, in main
spiflash.run()
File "/home/pi/klipper/scripts/spi_flash/spi_flash.py", line 1111, in run
self.run_reactor_task(self.run_sdcard_upload)
File "/home/pi/klipper/scripts/spi_flash/spi_flash.py", line 1095, in run_reactor_task
k_reactor.run()
File "/home/pi/klipper/klippy/reactor.py", line 269, in run
g_next.switch()
File "/home/pi/klipper/klippy/reactor.py", line 310, in _dispatch_loop
timeout = self._check_timers(eventtime, busy)
File "/home/pi/klipper/klippy/reactor.py", line 156, in _check_timers
t.waketime = waketime = t.callback(eventtime)
File "/home/pi/klipper/klippy/reactor.py", line 48, in invoke
res = self.callback(eventtime)
File "/home/pi/klipper/scripts/spi_flash/spi_flash.py", line 1074, in run_sdcard_upload
self.mcu_conn.configure_mcu(printfunc=output_line)
File "/home/pi/klipper/scripts/spi_flash/spi_flash.py", line 910, in configure_mcu
"Failed to Initialize SD Card. Is it inserted?")
SPIFlashError: Failed to Initialize SD Card. Is it inserted?
and yes it is the right /dev/tty* device and yes the SD card is inserted. Anyone got an idea?
