Perhaps this will help someone:
After an archlinux system upgrade, multiple different klipper boards could not be flashed anymore while reporting various dfu-util related errors, such as:
dfu-util: can't detacherror resetting after download (LIBUSB_ERROR_NO_DEVICE)
Testing with available dfu-util versions for the archlinux:
https://archive.archlinux.org/packages/d/dfu-util/
Produced the the following results:
dfu-util v0.9.X:
LPC1768-type board: flash: works, error message: noneSTM32f4-type board: flash: works, error message:dfu-util: can't detach
dfu-util v0.10.X:
LPC1768-type board: flash: FAILS, error message:error resetting after downloadSTM32f4-type board: flash: works, error message:dfu-util: can't detach
dfu-util v0.11.X:
LPC1768type board: flash: FAILS, error message:error resetting after downloadSTM32f4-type board: flash: FAILS, error message:dfu-util: can't detach
and when dfu-util is built from source:
- AUR (en) - dfu-util-git
- at commit:
be4961218b146296661069e4658a308a6eda36b9
dfu-util v0.11-DEV:
Perhaps deveopers could update flash_usb.py to reflect dfu-util versions:
klipper/scripts/flash_usb.py
